Old 11-21-13, 08:50 AM   #1
Minimac
Default Mixing valve for hydronic heating
Just wondering if a shower mixing valve would be an acceptable alternative to the higher priced mixing valves needed when combining a Pex system to a conventional hydronic system. I've seen people replace perfectly good shower valves when remodeling a bathroom. They are easily adjustable and cheap on craigslist. I know the Pex needs to run at a lower temp than the existing copper heating system I have. I'm thinking that this may be an inexpensive (cheap) way to combine the different zones. I'm planning on possibly running the pex for an under the floor system for my basement. I already have a 1/2 backflow preventer at my disposal for the cold side of the valve and the hot side would connect to the supply side on my boiler. Worth it or not?
Minimac is offline   Reply With Quote
