Old 02-08-20, 11:04 PM   #3
gadget
There are a few ways to approach this one.
First choice: Mad Max bartertown rube Goldberg contraption. Everything is independent of everything else and is simple as it can be. Cheaper but not so efficient or reliable.
This will be the route I will probably go since I already have the compressors. I would think efficiency should be good assuming my refrigerant systems are built correctly(I'm still learning in this area) Typically, cycling should be your biggest hit to efficiency due to pull down time. Also, it should be more reliable since a stage can go off line and the others keep working making heat.
I'm not sure how long the compressor would last in the first stage since it would be running constant for days and days.
gadget is offline   Reply With Quote
