I will try again
Poof
Rather then a aluminum frame I will be folding a sheet of coroplasts into a pup tent shape and rivet together using washers as backing along seams.
It will have a added fairing at the front end for wind protection and improved Aero
Once its in shape and riveted will spray canned foam along the inside seams for a hidden light weight framework..
It will be removable as a unit from the trailer. The plan is to stop and charge under the mid day sun
A labor of love something Im putting together for spring and summer camping when out Sunning and gold prospecting in the nice weather.
keeping weight down is paramount. The panels weigh 3.5 lbs each
