I did. Appears to be the last item to arrive.
The PLC will trigger the defrost. As jeff5may suggests in another thread, I think I'll give delta-T a try.
Although if I can get a ground-source heat exchanger happening soon enough, I can just switch to ground source if it gets too cold outside and abandon the reversing valve entirely.
