Skyking
The fans were approx $34.00 ea. (forgot to mention that sorry..
The 6 inch fans I installed in my hot air collectors were purchased at a place that sells all commercial HVAC plumbing equipment / boilers / that kind of place because the fans and fan wiring they offer can withstand higher heat temps. CFM? not positive what they are but you want to move as much air as possible when they kick in.
Another way to go with fans would be to use 12v fans powered by a battery recharged via ev solar panel. I've seen them around for sale. If you go that route you won't be using any electricity however you'd have to deal with changing out the battery now and then once it goes ca putt.
Pat from Warwick, RI
Please Note:
Comments and/or suggestions I make here at the forums on 'your' projects as well as my own have all been carefully and scientifically calculated by 'the seat of my pants' To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Reason: added price of fans
