One caveat on using scroll (or hemetic piston) compressors for vacuum:
ONLY use 120V motor compressors, if you use 240 scroll and pull a partial vacuum the air density gets below the Paschen minimum and the motor winding will arc over to the stator and you will destroy the motor.
