Originally Posted by WyrTwister
I had a 1/2" torque wrench , as you said , for sockets .
I bought a 3/8" torque wrench and 3/8" drive metric " crows feet " . In both " normal " and flare nut version . I had read to position the crows foot at 90 degree on the torque wrench . ( 3 o'clock or 9 o'clock )
If the spec on the mini split is 4.5 amps of 240 VAC , then the watts are lower than my unit at 10 amps of 120 VAC . Which is what I would expect , since I remember yours was a higher SEER than my 13 SEER .
God bless
Wyr
Have you got a link to the "crows feet" thingies? Might make sense to get.
