Old 09-03-09, 08:32 AM   #21
digger doug
Yeah, that is really the question. If I insulate right now with cellulose, that particle board is not coming off. If it did have to come off I would have a heap of cellulose to clean up and have to find a new way to blow it back in.
See my post about insulation blowers.....it's called commercial wall spray.
mix elmers glue with water 6-8 to 1, and go to town.
I've included 1 pix of the garage I did with it.
Can pull it off easily for re-model, and can fix it if you build your own
set-up.
Buy the insulation from Lowes, borrow the machine, add your nozzle & pump.
There's no cutting & fitting of sheets around obstructions when it comes out of a hose.....
digger doug is offline   Reply With Quote
