Gasstingy,
Yes, you can put in too much insulation. I have seen it done. I recommend about R40-R60 for the ceiling, in all but the most extreme lower 48. Walls max out at about R20-R30. One client insisted on doing R70 walls and R120 ceiling. I tried to explain that the return on this tripling made the pay off time literally about 200 -300 years. He would not buy it and spent far too much $ on this.
The performance data discouraged him. He though by putting in these large values, he could heat his home "with a lightbulb" - this was before CFLs or LEDS.
As an engineer, the major issue is "bang for the buck" with adequacy of design. With insulation, the return is not linear, but a 1/x relationship. So, for an attic, the return on the first inch is about one week, for the next four inches is 6 months, the next four inches about a few years and so on. Much beyond R-60 and you are just insulating with dollar bills.
If you look a U values, the inverse of R, then it is a linear relationship. In Europe, the U value is more widely used.
But basically it is just Ohm's law E=i/R or E=iU.
Steve
