My arms are still sore.
The color sanding process was this.
I worked on one part like fender at a time. I taped off adjacent edges.
All sanding was hand sanding. All buffing was with a power buffer.
Wet sand with 1200 clean sand again 1200 clean spot sand with 1200.
Wet sand with 1500 clean spot sand 1500.
Wet Sand 2000 clean
Buff with wool wheel Meguiar's 105.
Clean spot buff with Wool pad Meguiar's 105.
Clean foam pad Meguiar's 105.
Clean the foam pad use Meguiar's Mirror Glaze 82 Professional Swirl Free Polish
Clean then use the finish foam pad with Meguiar's G19216 Ultimate Polish clean then done move on.
I started out with Summit Racing compound but that did not work near as well as the above procedure.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
