That is the look he wants. His clear coat was badly peeling. It will be red again.
I wonder if your old cars clear cost is still holding up. That was some bad years for clear coats.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
