bummer.
This is what I use and quick hit on the ratchet might do the trick
Husky 3/8 in. Drive 5 mm Hex Bit Socket-H3DHBS5MM - The Home Depot
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
