Well, by the time I got home last night, the panel was already out of direct sunlight. It was a little warm so I did turn the pump on, but it only ran for a little bit and I'm sure it didn't do much. I'm a bit hesitant to just put the whole thing on a timer to run during the day as we've never had the whole setup up to temperature yet... A leak would be very bad news!
