You'd need to be very careful to be sure you aren't adding too much static pressure to the system because the blowers installed in dryers expect reasonably straight ductwork with soft curves and little restriction at the outlet. If you reduce the flow too much you'll end up taking longer to dry the clothes and use more energy to the point where it might not help even if you are extracting some of it.
