Hi Wyr,
I have two 9,000 BTU Hyper Heat units. The one that's having a problem is 21 or 22 SEER and the other is 28 SEER. The problem unit holds 1lb 12oz.
Hope that helps,
Shelby
Originally Posted by WyrTwister
Do the newer , higher SEER MS's use less refrigerant ( for the same BTU ) , compared to the older / lower SEER units ( like our 13 SEER living room unit ) ?
God bless
Wyr
