I worked on the mower a bit over the weekend. I thought I took some pictures, but apparently I did not. I'll get some soon.
Anyway, I reworked the front battery rack so it now only holds a single battery again. I also figured out how I want to make the rack that'll go right over the motor. It will be a separate piece that bolts to the front rack in the front and frame in the back. This will allow removal of the rack to get at the motor without having to remove both batteries/racks. Unfortunately, I did not have enough angle iron of the right size to make it.
