Ah, here is the motor. I just looked it up. Its a permanent magnet. These are a bit more efficient (in general) than series or shunt wound motors. I'm not sure what to think of its torque rating though. Seems very low. I'm thinking 27 ft/lbs sounds better.
https://www.surpluscenter.com/item.a...1&item=10-2424
