Old 11-02-14, 06:06 AM   #8
Mikesolar
Mikesolar's Avatar
The only real way to make it more efficient is to reroute the flue through a secondary HX. Is it is natural draft fireplace? If so, the flue is about as hot as it can get and the beast is probably only 60% efficient so any heat you can take from the flue will drop its temp. You then have to make sure the venting doesn't condense too much.
