Originally Posted by Student 07
Hi,
My current project is adding rigid insulation below the fiberglass, to add R value and keep the fiberglass from hanging down. When all the rigid insulation is in I plan on using foam to seal it air tight.
Another thing I may do is install Tyvek across the bottom of the joists as an additional measure. I contacted a DOW engineer and she said that would be an excellent application for Tyvek. She explained that basically a floor is just a horizontal wall. IMO the floor cavity should be protected like a wall cavity. I wouldn't want wind and moisture flowing across the back of the sheetrock in my walls, why would I want it on my floor?
Thats my plan too. Let us know how it works out!!!!!!!!!!
