You guys have a lot of insights and thanks a lot for your help. You need more data and I like taking data so you will get more soon. Today I ordered another of those 2 channel thermocouple reader. I will add one out of evap and paste one to the steel heater tank. I will also set up a controlled test and record data in a spreadsheet to maintain a record.
The compressor is not overheating, I have a cheap IR temp gun which shows compressor around 120F at end of a heat typical 10 min heat cycle and around 140 at end of long 50 min heat cycle.
