Old 02-09-12, 09:59 AM   #49
zick
Closed loop systems typically run at about 10-20 psi and have a pressure relief valve set at 50 psi, so your hose idea should theoretically work fine since car radiators typically run around 15 psi.
Solar Hot Water for Cold Climates: Closed Loop Antifreeze System Components
It would be a little more costly but you could always put on copper unions. This would definitely hold the pressure and still allow you to disconnect the panels if needed.
zick is offline   Reply With Quote
The Following User Says Thank You to zick For This Useful Post:
Daox (02-09-12)
