Old 04-03-13, 03:45 AM   #10
randen
Uber EcoRenovator
Here in Canada were the ground loop temp was entering the water to air air-handler at 45 Deg F in the shop with a humid 80 Deg F air temp. The result was that the conditioned air did reduce in temp and humidity but not enough humidity. The air became cool and clamy not so comfortable. As Stevehull mentioned the coil isn't cold enough to reduce the humidity to a comfortable level. I was very suprized as the water was just pouring out. I left it run 24/7 as the power usage was very low.
Randen
