Originally Posted by GaryGary
Hi AC,
I think either inside or outside works. I like the inside because its easier to install and you get no thermal bridging.
You can also do both -- especially if you don't want to give up too much of your tank volume to insulation space.
Gary
Gary,
Thanks for your reply. The data sheet volunteered by Snail:
http://thermotreatedwood.com/Researc...H%20+%20WI.pdf
...has some very important information that should be read by all.
