I modified sketch to be able to use multiple AM2301 sensors & to take 25 samples & average them before each Serial Print, this is done to smooth out a little bouncing around that I was seeing.
BTW, the 2 AM2301 sensors that I have on hand consistantly read RH about 2.7% apart from each other. I have ordered 3 more from China, I will probably have to correct for their offsets with code.
It would be easy to modify some more & have sketch energize a relay to run dehumidifier automaticaly and to stop cooling ceiling until humidity drops enough.
Code:
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
// Modified by BBP
// Sensors are wired to pins D2, D3, etc
#include <DHT.h>
#define NUM_SENSORS 2
#define SENSOR_STARTING_PIN 2 //D2
#define Sample_cnt 25
#define DHTPIN 2 // what pin we're connected D2
//#define DHTPIN 3 // what pin we're connected D3
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 // DHT 22 (AM2302)
#define DHTTYPE DHT21 // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
//DHT dht(DHTPIN, DHTTYPE);
float tF;
float dP;
float dPF;
float h;
float t;
float alpha = 0.9; // factor to tune
float average;
int i;
int I;
void setup() {
Serial.begin(9600);
Serial.println("DHTxx test!");
// dht.begin();
void loop() {
for ( I = SENSOR_STARTING_PIN; I < (SENSOR_STARTING_PIN + NUM_SENSORS); I++ )
DHT dht(I, DHTTYPE);
dht.begin();
// Reading temperature or humidity takes about 250 milliseconds!
// float h = dht.readHumidity();
// float t = dht.readTemperature();
average = 0.0;
for (i=0; i< Sample_cnt; i++)
average = alpha * dht.readHumidity() + (1-alpha) * average;
delay(10);
h = average;
average = 0.0;
average = alpha * dht.readTemperature() + (1-alpha) * average;
delay(10);
t = average;
// delay(10000);
// check if returns are valid, if they are NaN (not a number) then something went wrong!
if (isnan(t) || isnan(h)) {
Serial.println("Failed to read from DHT");
else {
Serial.print("Sensor Pin D");
Serial.print(I);
Serial.print(" ");
Serial.print("Humidity:");
Serial.print(h);
Serial.print("% ");
Serial.print("Temp:");
// Serial.print(t);
// Serial.print(" *C ");
tF=((t*9)/5)+32;
Serial.print(tF);
Serial.print("*F ");
Serial.print("Dew Point:");
// Serial.print(dewPointFast(t, h));
dP=(dewPointFast(t, h));
dPF=((dP*9)/5)+32;
Serial.print(dPF);
Serial.print("*F");
Serial.print(" ");
Serial.print("Heat Index:");
Serial.print(heatIndex(tF,h));
Serial.println("*F");
} //end else
} //end for loop reading sensors
} //end void loop
// delta max = 0.6544 wrt dewPoint()
// 6.9 x faster than dewPoint()
// reference: http://en.wikipedia.org/wiki/Dew_point
double dewPointFast(double celsius, double humidity)
double a = 17.271;
double b = 237.7;
double temp = (a * celsius) / (b + celsius) + log(humidity*0.01);
double Td = (b * temp) / (a - temp);
return Td;
double heatIndex(double tempF, double humidity) //how hot it feels
double c1 = -42.38, c2 = 2.049, c3 = 10.14, c4 = -0.2248, c5= -6.838e-3, c6=-5.482e-2, c7=1.228e-3, c8=8.528e-4, c9=-1.99e-6 ;
double T = tempF;
double R = humidity;
double A = (( c5 * T) + c2) * T + c1;
double B = ((c7 * T) + c4) * T + c3;
double C = ((c9 * T) + c8) * T + c6;
double rv = (C * R + B) * R + A;
return rv;
DHTxx test!
Sensor Pin D2 Humidity:36.00% Temp:70.16*F Dew Point:41.95*F Heat Index:76.38*F
Sensor Pin D3 Humidity:33.30% Temp:70.52*F Dew Point:40.25*F Heat Index:76.16*F
Sensor Pin D2 Humidity:36.10% Temp:70.16*F Dew Point:42.02*F Heat Index:76.39*F
Sensor Pin D3 Humidity:33.20% Temp:70.52*F Dew Point:40.18*F Heat Index:76.15*F
Sensor Pin D2 Humidity:35.99% Temp:70.16*F Dew Point:41.94*F Heat Index:76.38*F
Sensor Pin D3 Humidity:33.20% Temp:70.70*F Dew Point:40.33*F Heat Index:76.15*F
Sensor Pin D2 Humidity:35.90% Temp:70.16*F Dew Point:41.88*F Heat Index:76.37*F
Sensor Pin D3 Humidity:33.09% Temp:70.70*F Dew Point:40.25*F Heat Index:76.14*F
Sensor Pin D2 Humidity:35.80% Temp:70.16*F Dew Point:41.81*F Heat Index:76.37*F
Sensor Pin D3 Humidity:33.21% Temp:70.52*F Dew Point:40.18*F Heat Index:76.15*F
