I hate to comment on it too much. I found the leak the old fashion way. I knew where the leak was and I was not able to get it to detect the leak. It may work fine but it did not leave me with a great impression.
This was the first time trying it so if you know what you are doing with it might be good.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
