I get dirty. 2.5gpm wont cut it for me. Find the flow restricter, drill it out problem solved.
I would probably break that water recycling thing. At the end of a good day for me is black soapy water going down the drain.
All you have to do is turn off the water.
I found that using automotive vacuum tees and vacuum line couplers into the toilet bowl filling line fills the top tank faster and sends less water down the drain from over filling the bowl. This was after I adjusted the float lever to not fill the bowl as much.
