I believe we sell 134a for $20-$25 a pound here in sask, it's just about the only refrigerant I work with. You should be ok as far as contamination as when your reclaiming you generally use the sturdier dual valve tanks... But if your unsure you can figure it out with a temperature reading, a pressure reading, and this chart
R134a Refrigerant Pressure Temperature Calculator
