Thanks !
That looks easy enough. I talked to a guy that made it sound as if this sort of thing would be impossible -something about the "refrigerant not working right if the 'frig is turned on it's side."
So with this simple setup described above, I would also still have my freezer - right ?
( It appears as if the only change that was made to the unit is that it was modified to sit on its back )
Thanks again !
