I keep forgetting to post up pictures of the siding. But, I am kind of back on this project. I need some warmth to continue working on other things! So, I decided to put up a layer of plastic on the ceiling so if I use a heater, the heat will at least linger for a while. Before putting up this plastic, if I used my kerosene heater, I couldn't even tell it was on unless I was standing directly in front of it. Therefore I stopped using it and just lived with the cold and/or didn't work outside as much. From talking with others, this should help out a fair amount. Here are a couple pics.
In the middle of putting up the first sheet.
First sheet is all up. I have since added a second sheet up next to it. A third sheet has yet to go up (I have to clean all the junk out from up in the rafters), but the third sheet will seal everything up.
