Old 02-11-19, 09:08 AM   #14
pinballlooking
pinballlooking's Avatar
I added a skid steer quick release to my front-end loader.
I had to cut off my buckets bolt on brackets and weld on an adapter bracket to make it work with the quick release.
You can buy a new bucket but that cost $500 plus truck shipping. The adapter plate was $110 shipped.
I got a set of quick release pallet forks.
I used my plasma cutter to cut off the brackets this is the one I bought off eBay
https://ecorenovator.org/forum/showthread.php?t=5256
It worked great for this job. I will be using it to make some tractor attachments soon.
I used it to build a hand gun shooting this weekend. You can also shoot rifles at 100 yards or 150 yards on my porch or anywhere in between.
There is dirt piled up behind it for added protection.
Here is a video of someone using quick attach (on a bigger tractor than mine.)
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
