I have a LG, about 8 years old. It only had one minor problem in that time (drain pump failed, plus a cracked hose from when I replaced the pump). It uses a Peltier heat pump instead of a compressor, so efficiency, while great, probably won't be as good as some of the newer compressor based units available.
