Originally Posted by Xringer
The cost was $2,142.34 shipped. I've seen the Daikin specs on that 18k unit,
and the low temperature performance is about the same as the old 2009 Sanyo units that I'm replacing.
"Low ambient cooling to 5°F / -4°F with optional drain pan heater"..
This Crown Gree comes standard with a drain pan heater, and will work down to -20F..
At least that's the spec..
Yes I am in Southern CA so I don't need that low temp on the MS. Were you able to get the valve open? I wish you a great installation, I don't know if you have seen that installed 2 MS myself and also the first one by a technician. I am in love with these machines I can't wait for winter to test them out.
