Jeff it does seem like magic. You are correct any air leaks and that warm air will go away and not come back.
I have eight 55 gallon barrels on water and about 1,000 gallons of fish water. The black barrels heat up during the day and release heat at night.
The back walls and the roof are insulated with 4.5” Dow blue board foam insulation. That makes 22.5 R all OSB is covered with Grace Ice and water to prevent any air getting into the building.
This is better insulation and air sealed than my house.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
