The reduced power consumption of the unit running on propane is interesting. It was a 5000 btu unit to begin with, yes? If so, they usually draw around 500 watts.
The extra condensate is a bonus. You're grabbing latent heat out of the room, rather than cooling the room down. Water down the drain equals less energy wasted cooling the room. Hopefully it won't dry out the house too much.
