Seeing as how you get more heat out of the hot side with warmer air going over the cool side, then it seems like as you cool the compressor you should have that heat heat the cold side of the heat pump, that is assuming that the compressor is only getting in the 100 degree range or so, if it's hotter then that then I would be a little worried.
