Good progress. This was the point I wanted I wanted mine installed. All the money was spent but the benefits were not coming back.
Are you going to share the cost with us? It could help others thinking about installing solar.
Cost keep coming down as least for now.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
