Hello all,
A previous house I had used an Apollo Heating system that got its heat from a gas fired water heater, and had an air handler in the attic, with 3/4" or 1" cpvc pipe from the heater up to the air handler. It worked well, though I cannot remember just how effecient it was, I thought it worked pretty well. I'd do one again if I had gas into my house.
I'm not cheap, I'm just economical! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
