Its been a couple weeks but have found some time for more work on the HWHP. Decided to mount the compressor and evaporator on top of the tank. I drilled down from the top and between the tank and outside cover through the foam to run the condenser lines to the condenser copper HX coil. It worked very well and was easy. The connections are brazed up.
Further work is needed to finish mounting and connecting the compressor and evaporator. Following that a nice cover. I ordered up a new anode and treated the tank with an acid rinse. Looking though the bungs it looks brand new inside. I tried to take a photo of the cork screw HX in-side but no can-do.
Dad is quite interested now in his new HWHP.
Randen
