Originally Posted by ecomodded
Ii thought more on your concern with pump strength and decided to use less line to lighting the work load, instead of 70ft of poly I am going to use 20 ft. of 1/4" primmer covered copper tubing...
It might be useful for you to investigate the physics of fluid flow.
You will learn much.
