Best Method
The thermal grout in conjunction with materials that are at least as thermally conductive as the thermal grout is going to give you the best possible absorbing and radiation properties.
that means no plastic or anything with a lower thermal number then the thermal grout can be used anywhere in the system but supply lines, as it would be the limiting factor.
Rather then plastic or poly sealed copper or stainless steel is the solution , if you can justify buying it.
