I used the timmer for the first time this weekend. Overall, I'm very happy with it. Heres a quick list of pros and cons.
Pros:
lightweight
charges quickly
quiet
starts instantly
you don't smell like gas after using it
very adjustable
Cons:
needed to charge 3 times to do the whole yard (which admittedly is large and this is the first time trimming this year).
not incredibly overpowered like the gas trimmer it replaced (but is powerful enough to take down anything normal)
So, you can see the pros definitely outweigh the cons. The starting issue alone is worth it...
I'll do a more in depth review for the blog later this year after using it more.
