Thread: 12,000btu fuji
Old 01-26-14, 12:16 PM   #23
WyrTwister
Originally Posted by NiHaoMike View Post
Nylog Blue also works on R22 and R12.
Good to know , Thank you . :-)
I did not know if it would contaminate the mineral oil ?
I have read that Nylog is polymerized refrigeration oil ? In the case of Blue , I guessed it was POE ester oil ?
Before I start up my central A/C condenser , next spring / summer , I need to swap out the Schrader valves . ( I have the tool to do this w/o discharging the R22 . )
The system has a very slow leak , that I have not found anywhere else in the system & Schrader valves are a likely suspect ?
I had planed to coat the new Schrader valves with mineral oil , but from what you have told me , Nylog Blue would be OK , too ?
God bless
Wyr
