Originally Posted by jeff5may
Units a ton and a half or smaller can be fitted with a reversing valve and a defrost control, leaving the original metering device to control heat flow. Old school twisty knob units can be used with the original thermostat, modern button boxes benefit from adding a single stage heat pump thermostat. The whole retro fit can cost less than 100 dollars.
New plan , hacking a portable Ac with reversing valve that should have defrost control via some sensor. that has me thinking to mount the evape and fan unit outside and leave the case with compressor condenser and controls inside.
a Mini split on a short chain , slip the evap and fan unit out the window and let it rip.
I think its outlet fan will be powerful enough I would add a fan to cool the indoor compressor
That's the Mods I think of what else do i need to do with a automatic type unit like this ?
