Old 04-05-21, 03:50 PM   #5
pinballlooking
pinballlooking's Avatar
I did not buy this forklift the seller was not honest with the issues it had.
It developed a bad leak on the mast cylinder it looked like that it would need rebuilt and rechromed.
This is about 1,400 at the cheapest shop I could find but the best shop also.
Then the steering he fixed he did a ½ axx job did not replace the bottom bearing and did not cut the grove for the snap ring.
Just tacked welded it. I would have to redo it all. Needed a new started switch everything on it needed adjust or fixed. It had a flat tire with the others were cut.
I am still looking at this point.
I am not sure why people are not honest about condition not like I would not notice when I looked at it. Pictures that were provided were very old.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
The Following 2 Users Say Thank You to pinballlooking For This Useful Post:
Daox (04-06-21), MetroMPG (04-26-21)
