Originally Posted by Homeless
O.K., point 60 kWh for for 24 hours.
That amounts to what ... 219 KWh per year right ?
Not good enough.
60 kWh/day is a lot. Isn't it 60 Wh/day ? If yes then it's very efficient, my newer fridge is at 380 Wh/day = 140 kWh/year.
219 kWh/year = 600 Wh/day = 0.025 Wh/h and is more efficient than my older fridge at 660 kWh/year.
My fridge has two small ventilators at the upper part. They switch off as soon as the door is opened. I rarely saw them already off when opening the door.
Denis.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.- kg saved 06/08-08/09: 1816.9+382.9 (ecodriving / 1420mi not driven) = 2199.8
(2.66 kg/l diesel)
- kg saved by 3kWc photo-voltaic solar panels : 187 kg/yr
(59.1 g/kWh)
- Long life (>100,000 years) : 2.85 g/yr (0.9 mg/kWh)
- Short life (<300 years) : 31.7 g/yr (10.0 mg/kWh)
