As I understand gas heat is about 1/3rd the price for electrical heat, obviously this depends a lot on your local prices, you will have to convert everything to the same heat units, BTU is pretty common.
But, generally, if you can use gas heat anywhere at all, it is waaaaaay better than electric heat.
