Old 06-29-12, 01:04 AM   #2
Vlad
I don't really get this concept.
You use oil or gas to heat air inside your house and after you take this heat and steal it for water heating????
In warm climate yes it makes sense because this is your "free" AC. But when you heat your house I just don't get it.
For this reason I am going to use ground loop (closed water loop) as a heat source and I will build water to water 2 ton HP.
Vlad is offline   Reply With Quote
