I think this is an illegal line... with the minus in front of the equal sign:
Code:
steinhart -= 273.15;
Compound assignment operators in C and C++
+= plus equal sign
The part of the program that is at the top, in other words above...
... is where all variable name must be declared, or else the program will not know what the strange undefined words mean.
I may be wrong (I haven't installed the Arduino compiler on my new computer yet, so I can't try it today), but a variable defined in
setup() may not be visible in
loop() since those are two distinct functions. If you want a variable to be visible in both
setup() and
loop(), it must be declared
outside of the scope of either function, ie before the declaration of
setup() (after the
#define would be good).
