I do quite a bit of window installs old and new work. The rule of thumb with using replacements as apposed to new construction windows has alot to do with the age of the construction. Much older homes are more favorable for replacements. Where newer homes requiring windows typically require removing the entire window frame. Cost is alot more labor wise. every home is different
