Old 06-21-15, 10:13 AM   #11
oil pan 4
Land owner
Install a globe valve in series with the hot and cold water lines. Close the globe valve and set any flow rate you so desire.
Put the globe valve where you can reach them just in case they should start leaking some day. Make them accessible from the basement for put them behind an access panel.
